Flyzone Beaver lights
  • XF-15DCC
    • May 2015
    • 164
    • Bristol CT
    Just curious, is there a way to split the lights on the Beaver? I would like to make the landing light turn on and off with the position of the flaps and make the remaining lights controlled buy another switch.
    Off with one helluva roar!
    AMA 1085465
  • Iowa54
    • Sep 2015
    • 184
    RE: Flyzone Beaver lights
    I have a Beaver That I need to maiden and your question makes me wonder also if there is away to tie it into the flap servo with a Y cable.
    • XF-15DCC
      • May 2015
      • 164
      • Bristol CT
      I know I can use the same switch for flaps and landing light. I should be able to do that in my tatic 850. What I would like to do is slpit the lights. Make one switch just for the anti-k and position lights and the landing light mixed with the flap switch. Hard part would be dissecting the light harness and wire another servo end.
      AMA 1085465
