Hello Alpha and the rest of the MRC crew,
A lot of the 1400 and 1300 FMX birds use the same motor.
You folks carry the SU127 motor mount for those motors but it only has sheet metal screws to attach the Xmount to the firewall but no metric screws to attach the motor to the mount.
Unfortunately those metric screws are not available at local hardware stores and if your a modder like me that uses FMS stuff on other ARF's or you are just replacing a motors mount and buggar up the metric screw while removing(loctite) your now out of luck.
FMS makes the same Xmount with the metric screws included and no sheet metal which is ok because those screws are easily obtained.
The part number that I am requesting is SV127.
I do all my FMS part shopping via MRC except for this part which I am forced to reluctantly use your competitor.
How about upgrading your inventory from the SU127 to the SV127. Am pretty confident that the rest of MRC's customers would appreciate it to.
Thanx in advance,
Thanx in advance,
