Motor/Esc beeping continuosly with a FUT T-FHSS receiver and not with a FUT FASST receiver
  • BushPilot
    • Oct 2019
    • 11
    • Idaho Falls, ID
    Gents,
    So I finished assembling the High Performance A-6 today, I will refinish the bird later and add the callie graphics set but wanted to set it up and maybe even maiden it before the cold weather comes in (it is already here), I bought a Futaba R3008SB T-FHSS to use with this bird and use the telemetry capability to look at battery voltage, but I get a fast beeping sound and no servo works after I link transmitter and receiver, I have a Futaba T16SZA, I hooked everything to a Futaba R617FS and everyhing works great. If it worked on one it should work on the other......Please let me know if you have experienced something similar....Thank you.
    (I did put the trasnmitter in T-FHSS mode...just clarifying...jejeje)
  • taz101
    ɹǝʎlℲ ǝᴉssn∀
    • Dec 2017
    • 27
    • ɐᴉlɐɹʇsn∀
    Originally posted by BushPilot
    Gents,
    Try reversing the throttle channel!!
    Sounds like your ESC is not reading a low throttle setting, which it needs to initialise.
    I remember most Futaba radios need the throttle channel to be reversed.
    LURCH
    • BushPilot
      • Oct 2019
      • 11
      • Idaho Falls, ID
      LURCH
      Already did, that is the way it is set up w/the FASST RX, channel 3 is reverse. I will also try the receiver in another plane to make sure it is not a bad RX...….I do get a green light on the RX and the RX Id is shown on the TX....
      • BushPilot
        • Oct 2019
        • 11
        • Idaho Falls, ID
        Found the problem, the channel mode on the RX was set to mode D, changed back to default (mode B), problem fixed!!!!
