Admiral RX6600SP reciever in nitro plane???
  • Admiral RX6600SP reciever in nitro plane???
    Hello gentlemen, I want to use an Admiral RX600SP receiver in a new nitro project using a 4.8v nicad pack. I put the nicad pack into the "throttle" port and it powers up and binds to myTX as it should but I can't get the throttle servo to work. All other functions [ail, gear, elev, rud and flaps work fine].
    I've tried throttle servo on a "y" lead with the battery...no joy. I've tried putting the battery in the bind/aux port...no change. Everything continues to work normally EXCEPT throttle.
    Is there a different receiver I should be using? Does this 600sp only work properly with an esc/bec? This kind of BS was never a problem when all we had was nitro planes
    Never mind, I'm an idiot :-[ I forgot about the throttle cut !!!!
      No idiots here, we all have a brain fart every now and then. Glad you found t h e problem.
