I am looking for a Dynam BF-110 Manual. Paper or scan is fine. Just need some tech specs on CG and other data.
Dynam BF-110 Manual?
THB, welcome to Hobby Squawk! The CG is 80-85mm from the leading edge of the wing at the fuselage with the gear up and the plane upside down... Have fun! She flies good, but be ready to mix some rudder in the turns... It tends to want to go knife edge on you with just ailerons... Blessings! Jerry
Both props turn the same direction too, so be ready for a little torque on takeoff roll. Take it easy on the throttle...
Product Updates:- July 2, 2017 - The orientation of the flap servos on this aircraft require you to reverse the direction of one of the servos in order for the flaps to move in the same direction. This can be accomplished by either 1) putting the flap servos on two different channels and reversing the direction of one of the channels 2) replace one of the servos with a 9g reverse direction servo 3) use a servo reversing cable on one servo or 4) mechanically changing the direction of one servo (this requires advanced soldering skills). We are working with Dynam to have them include one normal and one reverse servo with this model, we apologize for any inconvenience.
If you need any additional assistance, please visit the Motion RC Help Center
I, too, am building the Dynam Bf-110. I also have the Dynam Hawker Tempest in the box.
Motion used to have assembly videos but I can’t find them. Are they still available?GP Sport Zero, scratch built MA Sky Skimmer, VQ SBD, Eflite Pulse XT & RV-9, FW Stinger 64, Hanger 9 Saratoga, GP P6-E Hawk, FMS Stuka & B-25, Lanyu Do335, PZ Albatros, Eflite Hurricane 25e, Airfield F4-U, Freewing P-51D, Dynam Tempest, Bf-110 & 182, GWS Mustang & Formosa, FZ Switch, Eflite L-4, RocHobby Critical Mass, Alien Aircraft Gadget, RCM&E scratch built CanDoo, Dynaflite Piece O’Cake, HK Ventus, FZ Beaver, Avios Sea Fury, Uravitch 52" OV-10, Herr Engineering J-3
Today I removed some foam and stuck in a 2500 battery to give this bird a better balance, CG is right on 83mm , I got to remove aton of nose weight since a 2200 Admiral battery is too light. This seems to be the best mod I can do outside of the correct style of tailwheel from a crashed TA-152. now it has the correct look!!!Just let me fly so I may be free
