E-Flite UMX Timber wiring issue
  • seanmourning
    After replacing my fuselage on a E-Flite UMX Timber, I don't remember which connector goes where on the Esc.
    • 8795
    Under those circumstances, you can figure it out by trial and error. You’ve got 4 slots on the ESC/RX. You’ve got 4 leads that will fit into those slots. Start with one. Just pick one, say the rudder and plug it into one of the slots. Power it up and try the rudder stick. If it doesn’t work, go to the next slot. Repeat till the rudder stick works the rudder and steering. Then pick another, say the elevator and do the same testing. Then aileron. What’s left will be the flaps. Next time, take a picture of the board with each lead labeled.
    • mshagg
      • 541
      • South Australia
      If you check the thread on rcgroups there some hand scribbled diagrams of the Rx/ESC brick. I won't post here out of respect for the artist who drew them :)
      • seanmourning
        Thank You!
