UBEC wiring/install.
  • PilotBrent
    • Jul 2020
    • 2
    Hello pilots, wondering about installing my bec if i can use a y-splitter by cutting +pos wire off on the esc plug that into the y-harness and also the bec into the y-splitter and then both into the throttle channel on my rx?
    2nd if I have a twin powered plane (with 2 esc's) is it still necessary to use a bec? Does the 5amp internal bec's of both esc's = 10amp total for the servos?
    Thank you.
  • Robert D Myers
    • Oct 2016
    • 3
    Sorry I don't know either.
    • Robert D Myers
      • Oct 2016
      • 3
      I am such a dumbbell
      • quitcherbitchen
        • 923
        • Altadena, CA
        Carefully remove the Red power line in the throttle cable by releasing it with a small screw driver and pull it out. tape or heat shrink it back. You might need it someday. Then plug that into a Y cable that has the red line and the BEC into the other side of the Y and plug that into the receiver. The Y needs the red power line otherwise you can't power the receiver. Check Castle creations website for a diagram. Also, the amps available is completely dependent on the BEC itself and its rating. Two 5amp Bec do not step up the rating to 10. They can only handle 5 amps.
        • PilotBrent
          • Jul 2020
          • 2
          Thank you.
