Throttle and Elevator sticks are reversed on DX8
  • Love2fly
    • Sep 2020
    Hi Guys, I have a DX8 transmitter which was working fine but after adding a new plane, the throttle stick works the elevator and the elevator stick works the throttle.
    Have any of you seen this before?
  • ICM
    • Oct 2017
    • 226
    Check the connections to your RX. Throttle is is channel 1 and elevator is 3 on Spektrum or compatible RX
      • 8831
      Looks to me that you somehow managed to change the TX from "mode 2" to "mode 1". I'll bet your left stick also controls the AIL and your right stick controls the RUD. Go into the TX and find the place in the menu where you can select the "mode 1 or 2" and change it back to "2".
      • Love2fly
        • Sep 2020
        Xviper you were right....I changed the mode and its back to normal.
        Thank You
        • Riche richi
          • Aug 2021
          I have a nx8 the throttle sticks are swapped around can someone help me put them back the way they were
          Last edited by Riche richi; Aug 28, 2021, 08:08 PM. Reason: I have a nx8 the throttle was on the left side now it's on the right side I don't know what I did to do that but I need some help to put it back on the left side
            • 8831
            What do you mean: Sticks? There's only one throttle stick. And what do you mean it's swapped around? Please be more specific.
            PS. Did you see my post #3?
