Esc connectors to 46 eflite motor
  • flyguysc1
    • Sep 2020
    • 42
    I have a 80 amp esc eflite with 4mm connectors and a 46 size eflite motor which has 3.5 mm connectors.My question is will this work or do I have to change the connectors?I think that the motor would be the one to change but not sure any help would be appreciated.
    • 8795
    No, it won’t work. You’re trying to put a 3.5mm pin into a 4mm hole. Change one or the other. Personally, I’d change the 3.5mm pin to the matching 4mm pin.
    • flyguysc1
      • Sep 2020
      • 42
