Guys:
I contacted friends at motionrc and they pointed out this is the place to order new planes...
I am a lover of EDF Jets, and I would love to be able to fly the BlackHorse Viper Jet MKII
VIPER JET MKII
Item code: BH175.
SPECIFICATION:
– Wingspan: 1,885 mm (74.21 in).
– Length: ,1820mm (71.65 in).
– Weight: 8.9 – 9.1kg (19.58 – 20 lbs).
– Wing area: 62.2dm2.
– Wing loading:143.1g/dm2.
– Wing type: Naca Airfoil.
– Gear type: Electric retract gear, size: (92.55 x 51 x 35.1)mm (not included).
CNC Suspension Metal Struts (included).
Parts listing required (not included):
– Radio: 8 channels minimum.
– Servo: 8 standard high torque servos, size: (33 x 17)mm.
– Engine: EDF 120mm.
– Battery: 10S – 12S LIPO 37V- 44.4 V.
– ESC: 160A.
Recommended EDF and Battery set up (not included):
– Engine: Ducted Fan EDF JETFAN-120 eco Ejets+ HET 800-68-685.
Battery: 12S LIPO – 44.4 V ≥ 6000mAh 40C.
– Or Engine: Ducted Fan EDF Schubeler DS-86-AXI HDS 120mm + TP 5660-9D motor.
Battery: 10S LIPO – 37V ≥ 6000mAh 40C.
– ESC: 160A Phoenix Castle.
OPTION ELECTRIC RETRACT GEAR (NOT INCLUDING).
ONLY INCLUDING CNC SUSPENSION METAL STRUTS.
ALL BALSA – PLY WOOD CONSTRUCTION.
COVERED IN A HEAT-SHRINK FILM WITH PRINTED
let me know what you think of this wonderful model
I thank MotionRC for their customary collaboration to help us fly the most amazing models on the market
thanks to all....
Julio Inostroza
VIPER JET MKII
Item code: BH175.
SPECIFICATION:
– ESC: 160A.
thanks to all....
Julio Inostroza
