Tried to replace the motor by removing the set screw visible through the top of the fuselage as well as disconnecting the three wires. However the motor will not pull free.
I pulled so hard the prop came off so then I used visegrips on the prop shaft and was pulling hard enough for the motor mount to move in the fuselage.
Any thoughts on how I can get the motor to break free of the mount?
