Hello all, it has been a minute since I last was here. I am on a different kind of project right now and have a servo question. The project is setting up a commercial zero-turn mower for RC.
I have all the hard parts pretty much nailed down, but the one I thought would be relatively easy is turning out not so much. I am setting up an FPV system with a Walksanail Avatar HD camera.
I have Sky Zone Cobra V4 goggles, and I downloaded and 3d printed the parts needed to put together a simple pan and tilt setup from Painless 360 on YouTube.
I'm using the Walksnail VRX to plug the HDMI from the goggles to the VRX and am plugging the goggles head tracking cable into my FrSky X20s ethos radio.
That all works pretty much flawlessly; the problem I'm having is the pan and tilt 9-gram servos keep burning up, and I can't find any reason why.
The one thing I'm wondering about is my servo wire length.
Because of the physical locations of my head tracking servos and my receiver in my electronics control box, the wires need to be about six feet long. Would servo wire length possibly cause servos to brick?
At one spot the servo wires run closely along side wires carrying 12vdc but only about 3amps. Could they be picking up some kind of noise, maybe ferrite rings at each end would help?
One of the first servos literally melted down, and the smoke visibly left the building. I have continuity tested all six of the individual wires, and they are perfect in every way. If I plug a servo with a stock-length lead into the pan and tilt channels, it works fine. I'm kind of out of ideas except for the wire-length thing.
