3D Printing
  • i_like_planes_27
    • Aug 2024
    • 17
    3D Printing
    Hey everyone, I didn’t know which channel to post this in so I’m just gonna put it in general. I have a plan to 3D print and build a 757 airliner. I don’t know much about 3D printing and that kind of stuff but we have access to those big fancy ones. I am wondering what you guys recommend which app to use to design my project and then print it out, or is there specific apps for the specific printers?
    thanks
  • kallend
    • 1877
    Pretty much any CAD program can be used to design parts for 3D printing.
    I suggest you start with something more modest than a 757. Maybe a Sidewinder missile or something simple like that, until you get the hang of it.
    • testfly
      • May 2024
      • 12
      thanks
      Before I got into 3D printing I created 3D parts for a DIY MD-87 Airliner I cut from foam. I finished all of the main parts but have yet to put it all together to be flown. I used Turbo Cad and a 2'X4' cnc machine and a hot wire to cut the foam parts. ​https://www.seabreezeparachutes.com/md-87/view.html
      Now I do a lot of 3D printing and I use Tinker Cad to design parts for small models. I have created 4in1 board mounts, servo mounts, motor mounts, receiver mounts, battery hatches, sontrol horns, control hinges, spinners and I am about to start working on wheels and tires.
      When designing parts for small models you want them to be light and yet strong enough to do the job.
      The process is a lot of fun for sure.
      As suggested, You might start with something small. But, as you can see by the MD-87 project I didn't, so it can be done either way. :-)
      Good Luck
        • 7415
        As I try to find gear doors for my Freewing Mustangs in amongst the pile of used ones with broken pins, I kept thinking to myself, "There has to be a better design", so I started 'tinkering' around on Tinker Cad (Where else?). These are just doodles as I've not taken exact measurements, but it looks pretty legit to me, see what you think..
        Click image for larger version  Name:	Better landing gear pins.png Views:	0 Size:	93.8 KB ID:	445734 The center shaft is a separate unit and a spring would go between the two outer dowels, allowing the pin to slide back into the rearmost dowel. The rearmost dowel would contain the gap into which it would slide and a pin on the back would fit into the hole in the gear bay.
        Click image for larger version  Name:	Better landing gear pins 2.png Views:	0 Size:	66.3 KB ID:	445735 the two outer dowels would fit onto these base pieces, allowing you to glue them straight onto an existing gear door after trimming away the original pin system. With the system in place, you could slide the pin back, fit it into the wing and let it spring into place. Seems to me that it would be a much sturdier system.
        Thoughts??
        (Dangerous Dan)
          • 7415
Name:	Better landing gear pins 3.png
ID:	445737 Click image for larger version
Name:	Better landing gear pins 4.png
          Better break down of the parts
          (Dangerous Dan)
          • kallend
            • 1877
            Try it and see. Worst you can do is waste about $0.10 worth of filament.
            You may have to experiment to get the clearances right.
              • 4866
              Danger,
              Are those the Main Gear Door struts?
              That's my presumption, I do not have a Mustang (yet) so I am quite ignorant here.
              Best, LB
                • 7415
                Yeah, the main gear doors on the Freewing Iron Ass/Old Crow Mustang
                Click image for larger version  Name:	IMG_3233.jpg Views:	0 Size:	93.6 KB ID:	445762
                As you can see, the pins are pretty weak and a more robust design is needed. This way, you can also reuse old doors with broken pins.
                My original thought was to spring load the mechanism, but I could put a notch for the slider to fit in and glue it once its in place.
                (Dangerous Dan)
                • kallend
                  • 1877
                  It's not just the Mustang. Several of the FW EDFs have similarly weak door pins (mostly on nosegear) and I have found myself 3D printing replacements several times over the years.
                    • 7415
                    The thing was that you had to order the complete set in order to get the one gear door you needed, I have a box full of clam shells and rear gear doors.
                    • kallend
                      • 1877
                      Yep!
                        • 4866
                        Hey all,
                        I have run across an alternative "Free" CAD program and it is also 'open source'.
                        In many ways this one mimiks TinkerCAD, but with features found in Fusion, Onshape, and other more complex programs.
                        It runs in your browser rather than the cloud, so you must save to file on your computer, but I prefer that actually and do that using 3MF files for work I don't want to lose.
                        It is called Layering and the link is below.
                        I have been bouncing back and forth between T-CAD and Layering (LYG) with the same project (FW F-14a IPs) and I am pleased with the work.
                        I have no dog in this hunt, but it's great to finally have an open source design CAD for 3D printing that is not tied to the cloud.
                        The program is updated constantly, read daily so far; have fun with this one.
                        Best, Steve
                        Start layerling like a normal program, even without a network, and how to run it on your own computer.
                          • 4866
                          Hey All,
                          Update about using Layerling 3D CAD and as previously written, "I have no dog in this hunt".
                          Notably, TinkerCAD has just added "Image Import" to it's menu.
                          Basically this allows you to import a png or jpeg image for tracing or placement of parts you create.
                          Previously, only SVG files where importable into T_CAD for reference.
                          I have not tried using it with their "Sketch" Tool, but you can easily imagine the possibilities.
                          This image import is standard with Fusion and other larger CAD software.
                          Glad to see AutoDesk adding this feature for us amateur CAD users.
                          This import image feature is standard with LayerLing CAD and I've been using it with Sketch for my Tomcat Pilot IP.
                          I am doing this same project in both T-CAD and LayerLing just for my own edification and I will post anything that strikes me as relevant as the projects progress.
                          I have zero training or education with regard to CAD design, so if I can do this anyone with half a brain and some perseverance can as well.
                          The shaded blue-gray are Sketched for the most part; some basic shapes are are standard box and cylinders from the Shapes Menu.
                          The dark lines are the import image from a jpeg cleaned up in AdobePS.
                          Layerling is free like T_CAD, but is an open-source program which runs from your browser, not the interwebthingy or the cloud.
                          Impressive to me, but I am a simple man.
                          Best, LB
                          Click image for larger version  Name:	Kwik Look Dan.jpg Views:	0 Size:	132.1 KB ID:	453915
                          • jetfool
                            • Nov 2022
                            • 1358
                            • Crawfordsville, Indiana
                            Elbee,
                            Great to hear your still enjoying this hobby we all have. Are you working on a new F-14?
                            Best Regards, Rex
