Can't throttle when disconnected from Inav
  • mohamedmartinez
    • Oct 2024
    Hello,
    I've set up Inav on a SpeedyBee F405Wing Mini. In the outputs tab I can spin the motor. I've added arming and set it to a switch on the tx. I've had max throttle when turning the plane on to let the esc calibrate. All prearm checks in Inav are green. Why won't it let me go???
    Any advice? Thanks in advance!​
