I'm hoping someone can clear up my confusion/newguy stupidity... This is for assembling the RocHobby Waco.
I was expecting to see a Y harness included to link 2 aileron leads together to go to the RX.
Instead, what's included is a harness (what's it called, a double-Y?) that has 4 female ends going to into one - yet there are only the 2 leads from the left & right wing servos.
At the same time, I don't know what you're supposed to hook up the navigation light leads to. I also thought there might be a 2nd Y-harness for that, which would plug into an Aux port on the RX. Wrong there too.
So the manual shows a diagram just showing the Aileron's going to a channel(1, "Aile"), and it shows the "Steering/Rudder4". plus LED, plus LED going to another channel(4, "Rudd").
Huh? So do the two aileron leads go to this 4-part harness, or not? Or do the rudder and nav lights use it? If they use it, then I sure don't have a clue as to what the intent was for the ailerons... Am I missing a point, or a part?
