Thank you Callie
  • Hippie 64
    • Feb 2014
    • 1049
    • Gaffney , S.C.
    Thank you Callie
    I am so happy with the way this turned out . Callie's Graphics look fantastic
    But Crashing is Landing
  • Flygirl
    • 969
    • Glen Burnie, Maryland USA
    Sweet Bry!!!!!! How is the speed on that? Can you slow it to be more scale flight?
    Lauren
    • Prowler901
      • 940
      • Gunnison, CO
      Beautiful! Is that the Dynam or the Hobbyking?
      • Hippie 64
        • Feb 2014
        • 1049
        • Gaffney , S.C.
        Unfortunately it is the HK , I hate dealing with them . I got this before the Dynam was with MRC with the v2 wheel steering . The rear wheel use to be free turning . Thanks FlyG I've not had it up yet . Been reading lots of rumors with CG issues so it's not hit the field yet . I'm so happy with the way it turned out I'm almost scared to take it out
        Bryan
          Beautiful livery! Pan Am aircraft schemes through the years always had a nice "pop" to them.
            • 2816
            • Arlington, TX
            Nice work, a true Golden Age classic! I'm sure it will be fantastic in flight! Just be sure to double check the security of the motor mounts. I believe some of the earlier versions had issues with them being poorly attached. As for the CG and control throws, there is a huge thread about this plane over on RCG where you should be able to find that info.
            • doctormike
              HobbySquawk Moderator
              • Oct 2013
              • 1260
              • Santa Fe NM
              The silver paint, graphics, and Varathane made my Dynam C-47/DC-3 conversion very tail heavy. I have to use a larger battery to balance it. It's amazing what a little weight with a lot of leverage can do. Doc
