Batteries is one of the problems I have been dealing with going to electric from gas. My first post I was looking for help with motors, and Dewey H Lee wrote right here so I took he was talking about himself, but he was talking about Hobby Squawk members. So I will copy my post here.
My son gave me three systems! Why ?
First system! EM 3708 1135KV I built a piper cub 24” WS w/2 cell LIPO
Total weight under 12 oz –14 oz
Continuous Current: 25A
#2 EM 3714 893 KV I rebuilt a trainer 40” WS Total W. 2lb
#3 CF 2822 LITTLE MOTOR 18” WS piper 1C LIPO
T.W. 8oz
Emax CF2822 1200KV Outrunner Brushless Motor for RC Aircraft Helicopter
High quality light weight brushless motors with rotating case, suitable for all models of 200-600g. Max =1.2lb
Motor is accurately CNC machined for smoother and quicker running.
Bearings are made of high temperature and high carbon steel.
Specifications:
Number of cells: 2-3 Li-Poly
RPM/V: 1200 RMP/V
Max. efficiency: 82%
MAx. efficiency current: 7-16A(>75%)
No load current/10V: 0.9A
Current capacity: 16A/60s
Internal Resistance: 150mohm
Stator Dimensions: 22 * 10mm
Shaft diameter: 3mm
Recommended model weight: 200-600g
Recommended prop without gearbox: APC 7*6, APC 8*3.8, APC 9*4.5, APC 10*5
Item size: 3 * 4.8cm (Diameter * Length)
Item weight: 43g
Package size: 5 * 4 * 4cm
Package weight: 45g
Package including:RM234
1 * Brushless Motor
Description:
4X 30A Brushless speed controller ESC MultiCopter KK Multi-Copter Quad X-flying
Compatible with: 400-450 helicopters / Aircraft or Quad-Rotor Multi RC Heli
HOBBYPOWER 30A
Program same with Hobbywing 30A
4 sets good for quad-rotor KK multi-copter
quantity:4 sets
Specification
1.1 Output: Continuous 30A, Burst 40A up to 10 Secs.
1.2 Input Voltage: 2-3 cells lithium battery or 5-8 cells NiCd/NIMh battery.
1.3 BEC: 2A / 5V (Linear mode).
1.4 Max Speed: 210,000rpm for 2 Poles BLM, 70,000rpm for 6 poles BLM, 35,000rpm for 12 poles BLM.
(BLM: BrushLess Motor)
1.5 Size: 45mm (L) * 24mm (W) * 10mm (H).
1.6 Weight: 25g.
2 Features
2.1 Safety Arming Feature: Regardless the throttle stick position, the motor will not spin after battery connected.
2.2 Throttle Calibration: Throttle range can be configured to provide best throttle linearity, fully compatible with all market available transmitters.
2.3 Programmable Items:
Brake Setting: brake enabled / brake disabled.
Battery Type: Li-xx(Li-ion or LiPo) / Ni-xx(NiMh or NiCd).
Low Voltage Protection Mode(Cutoff Mode): Gradually reduce the output power / Cutoff the output power.
Low Voltage Cutoff Protection Threshold (Cutoff Threshold): low / medium / high.
Start Mode: normal / soft / very soft.
Timing: low / medium / high.
Reset: reset all the programmable items to their default settings.
2.4 Full Protection Features: Low voltage cutoff protection / Over-heat protection / Throttle signal lost protection.
- Max. Current: 35A
- Input Voltage: 6 - 18V
- Max. Efficiency: 98%
- No Load Current: 0.8A
- Internal Resistance: 65m ohm
- Motor Dimensions (Diameter x Length): 37.2mm x 24.7mm
- Dimensions: 51mm x 24mm x 8.3mm
- Sustaining Input Voltage: 6 - 18V
- BEC Output Current: 5V/3A
- Continuous Output Current: 30A
- Max. Output Current: 40A/12s
- Internal Resistance: 0.0021m ohm
- Input Battery Types: NiCd/ Nimh/ Li-po Battery
- Recommend Model: Helicopter / Airplane
- Continuous Current: 42A
- Max. Current: 50A
- Input Voltage: 8 - 23V
- No Load Current: 0.9A
- Internal Resistance: 74m ohm
- Motor Dimensions (Diameter x Length): 37.2mm x 41.1mm
- Shaft Diameter: 3.93mm (Front and Back)
- Dimensions: 67.8mm x 38.2mm x 12.5mm
- Sustaining Input Voltage: 6 - 30V
- Continuous Output Current: 80A
- Max. Output Current: 90A/12s
- Internal Resistance: 0.0018m ohm
T.W. 8oz
Specifications:
RPM/V: 1200 RMP/V
Shaft diameter: 3mm
Item weight: 43g
Package weight: 45g
1 * Brushless Motor
Description:
HOBBYPOWER 30A
quantity:4 sets
Specification
1.6 Weight: 25g.
2 Features
.png)
