Re: Foam vs. Balsa/ply models
X-Yahoo-SMTP: SJZWTEiswBAByO5vLObh7C5B2Rdtd.3sbMtPXjV5fA--
X-Rocket-Received: from [192.168.1.67] (msorensen2@99.99.18.91 with plain [98.138.105.21])
by smtp207.mail.gq1.yahoo.com with SMTP; 25 May 2014 15:14:32 -0700 PDT
Content-Type: multipart/alternative;
boundary=Apple-Mail-81FEA472-4F5A-4590-86A7-5A49E38CF3D8
Mime-Version: 1.0 (1.0)
Subject: Re: Foam vs. Balsa/ply models
Message-Id: <8BE4CE12-5E2B-4DC5-8D73-8C951F1DF9A9@att.net>
Date: Sun, 25 May 2014 18:14:32 -0400
References: <1390602226889-1601.post@n5.nabble.com> <1400974686092-2324.post@n5.nabble.com> <1400993882390-2326.post@n5.nabble.com> <1401038869406-2333.post@n5.nabble.com>
In-Reply-To: <1401038869406-2333.post@n5.nabble.com>
To: "Baron [via Motion RC Community Forum]" <ml-node+s1075610n2333h46@n5.nabble.com>
X-Mailer: iPad Mail (11D201)
X-SA-Exim-Connect-IP: 98.137.177.227
X-SA-Exim-Mail-From: msorensen2@att.net
X-SA-Exim-Scanned: No (on joe.nabble.com); SAEximRunCond expanded to false
--Apple-Mail-81FEA472-4F5A-4590-86A7-5A49E38CF3D8
Content-Type: text/plain;
charset=us-ascii
I managed to get everything straight again with the hair dryer only to find t=
hat the lower wing aileron tabs were not there and I had create then from od=
ds and ends. I also took trips to Ace Hardware to get screws that would fit=
. I hope this WACO flies after all this extra work building the plane. Gue=
ss I need to send a note to nitro planes about their product. =20
Sent from my iPad
> On May 25, 2014, at 13:27, "Baron [via Motion RC Community Forum]" <ml-nod=
e+s1075610n2333h46@n5.nabble.com> wrote:
>=20
> I have the had the Dynam Waco, rhymes with taco, for over a year and it no=
t only looks great but it flies great. I also had a slight bend in the eleva=
tor. I also used a hair dryer that had a heat and a cool set to get the edg=
es more aligned. Don't let the heat get too close to the foam as it will "al=
ligator" the surface. The one irritation of the plane was the strut screws n=
eed to be bit longer to get a secure fit but I have a whole lot of extra scr=
ews from many other planes that have long since past into hangar heaven. I a=
lso used Locktite (the blue solution) on the screws. As soon as MotionRC get=
s the Dynam line in a few weeks get that Waco biplane (if you are an interme=
diate flyer). It is a lot of fun.
> There are basically only two kinds of planes: fighters and targets- Manfr=
ed Von Richtofen
>=20
>=20
> If you reply to this email, your message will be added to the discussion b=
elow:
> http://motion-rc-community-forum.1075610.n5.nabble.com/Foam-vs-Balsa-ply-m=
odels-tp1601p2333.html
> To unsubscribe from Foam vs. Balsa/ply models, click here.
> NAML
Content-Type: text/html;
charset=utf-8
<html><head><meta http-equiv="content-type" content="text/html; charset=utf-8"></head><body dir="auto"><div>I managed to get everything straight again with the hair dryer only to find that the lower wing aileron tabs were not there and I had create then from odds and ends. I also took trips to Ace Hardware to get screws that would fit. I hope this WACO flies after all this extra work building the plane. Guess I need to send a note to nitro planes about their product.
Sent from my iPad</div><div>
On May 25, 2014, at 13:27, "Baron [via Motion RC Community Forum]" <ml-node+s1075610n2333h46@n5.nabble.com> wrote:
</div>
</body></html>
charset=us-ascii
Sent from my iPad
>=20
ed Von Richtofen
>=20
>=20
elow:
> NAML
charset=utf-8
</div>
<div>
I have the had the Dynam Waco, rhymes with taco, for over a year and it not only looks great but it flies great. I also had a slight bend in the elevator. I also used a hair dryer that had a heat and a cool set to get the edges more aligned. Don't let the heat get too close to the foam as it will "alligator" the surface. The one irritation of the plane was the strut screws need to be bit longer to get a secure fit but I have a whole lot of extra screws from many other planes that have long since past into hangar heaven. I also used Locktite (the blue solution) on the screws. As soon as MotionRC gets the Dynam line in a few weeks get that Waco biplane <i>(if you are an intermediate flyer</i>). It is a lot of fun.
<div class="signature" style="margin-top:1em;color:#666666;font-size:11px;">
There are basically only two kinds of planes: fighters and targets- Manfred Von Richtofen
</div>
<hr noshade="noshade" size="1" color="#cccccc">
<div style="color:#444; font: 12px tahoma,geneva,helvetica,arial,sans-serif;">
<div style="font-weight:bold">If you reply to this email, your message will be added to the discussion below:</div>
http://motion-rc-community-forum.107...1601p2333.html
</div>
<div style="color:#666; font: 11px tahoma,geneva,helvetica,arial,sans-serif;margin-top:.4em;line-height:1.5em">
NAML
</div></div>
</div>
</div>
NAML
</div></div>
