build sheet needed
  • Kenbob
    • 6
    • Henderson, Mn
    build sheet needed
    I recently purchased a 1880mm Skyline Corvus ARF. It came without any assembly instructions at all. I am new to building and thought it would make a great winter project. I got the shell put together, but have no idea as how to install the stabs, or where to locate the servos etc. I have gotten a recommendation on what electronics to purchase, but installing them will be a nightmare without instructions.
    I would appreciate any help I can get.
    Ken in Mn
  • WintrSol
    • Nov 2013
    • 499
    • Florissant, MO
    I see a servo mount position, on the floor of the cockpit just behind the cut-out on the starboard side of the fuselage. You can tell, because it is rectangular, with two little holes in the center of the short sides of that rectangle. You will probably find similar cut-outs for the other servos. Photo doesn't show enough of the tail to spot how the stabs are mounted, though.
    pretty sure this is the manual you want: http://www.generalhobby.com/manuals/...-30cc-72in.pdf
    or, it could be this one: http://www.generalhobby.com/manuals/corvus_70e.pdf
    • Kenbob
      • 6
      • Henderson, Mn
      Thanks this is perfect.
