Twin engine aircraft
  • corsair167
    • 57
    • shortly, Ft Mill S. Carolina
    Great Planes Twinstar
    No luck getting engines (motors) to sync. 2 motors with 2 esc's and one battery. I have seen reports on problems with "Y" on 2 esc's. what to do? I already set high and low on each motor separately. Modifying the Y connector? I have left motor running a pusher prop and right motor using a tractor prop
  • bradl4648
    Your Motion RC CS Team Rep
    • 369
    you did cut one esc red wires out correct? But before you do that unplug one esc from the receiver and do a throttle re-initialization first on each esc on their own then cut the red wire off one. This should make each motor run the same.Typically the right is clockwise and left is counter clockwise in rotation.
    Hope this helps!
    • WintrSol
      • Nov 2013
      • 499
      • Florissant, MO
      If that doesn't work, do you have a spare channel? If so, you may be able to slave one channel to the throttle, and make minor adjustments to subtrim and control range. You still have to disable one BEC, though.
        • 8831
        It may have been better to stick to your original thread: https://www.hobbysquawk.com/forum/rc...c-twinstar-arf
        This way, readers can have a little background and continuity and see what's been happening with this situation.
        • corsair167
          • 57
          good idea......why should a red wire be cut from one ESC?
            Because "standard" switched ESC's will fight each other......you can only have one of the two hooked to the Rx. You do not need to cut the red wire......just lift the keeper on the connector and pull the pin out and elec tape it from ground contact since it is a voltage potential.
            • corsair167
              • 57
              Thanks, good idea i'll try it
