I have a Mini Switch that I have changed to the low wing setup but I'm having a problem getting the CG right . Book says 68mm , set my balancer there and moved battery as far back as I could , there is not much room in the battery compartment . Still very nose heavy . There is no way to get into the tail area of this plane so not quite sure where or how to add extra weight . Any help out there ? Hippie
