Please consider adding the Do 335 to your Flight line RC line. If you make it the same scale as your very nice Ta 152H, you already have the cowl, front spinner, front prop, exhausts, and supercharger intakes. The main gear could probably carry over also. If not, a T-28 probably has very similar gear. The scale main wheels are fairly large and with tricycle gear, it should handle grass better than most tail draggers.
There are many variants to choose from but I would go with the A-0, painted like the one in the Smithsonian. Anyone who wanted a different variant could modify the A-0 into any of them.
Thanks!
Thanks!
