Remove E-Flite stickers
  • Remove E-Flite stickers
    I'm removing all the decorations from an E-Flite Opterra. I'm surprised how easy they peel off. Makes me wonder how well paint will stick. Here is my first question of today:
    is there a foam adhesive that you can then use a hot wire to cut through and shape?
    Hi Boots,
    I take it you want to glue something and then cut the shape with a hot wire is that correct. You do not say the sort of area you want to glue. However you can use "Foam Tac" to glue and cut through parts of it with a hot wire.
    Martin.
      Thanks Martin!
