Official Announcement: Flightline 2200mm XP-67 Moonbat..............Sike!
  • Official Announcement: Flightline 2200mm XP-67 Moonbat..............Sike!
    The XP-67 Moonbat would be a great future addition for FLRC...don't you think?
    Click image for larger version  Name:	16865036_10212532866586116_7285684949444714891_n.jpg Views:	1 Size:	156.9 KB ID:	64740
    Click image for larger version  Name:	17016066_10212532825665093_3552966287511002339_o.jpg Views:	1 Size:	93.0 KB ID:	64741
    Click image for larger version  Name:	17017032_10212532867546140_4110096343792132006_o.jpg Views:	1 Size:	125.7 KB ID:	64742
    XP-67 Moonbat
    The McDonnell XP-67 was a futuristic prototype which featured a smooth laminar-flow airfoil section throughout the design, a pressurized cockpit – unusual for the time, and it was to be heavily armed with a combination of machine guns and cannons. The complicated aerodynamic shape of the aircraft was developed through a test program conducted by McDonnell, NACA and the University of Detroit. Wind tunnel testing showed problems with cooling airflow for the engines, a problem which was never rectified and ultimately doomed the project.
    The McDonnell XP-67 began ground tests in December 1943. It was fitted with experimental Continental XIV-1430-17/19 engines and General Electric D-23 turbo-superchargers. Just a week later the aircraft was damaged by fires in both engines, caused by a malfunction in the manifold slip rings. By January 6th 1944 the aircraft had been repaired and it went for its maiden flight. However just 6 minutes later it was back on the ground due to engine problems. After further modifications to the engines it took to the skies again, but on the fourth test flight the engine bearings burnt out.
    While the engines were proving to be unreliable, it was also becoming apparent that they were also underpowered. Continental had promised the engines would each deliver 1,350 hp, but as it turned out they were only providing 1,060 hp – effectively robbing the XP-67 of 580 much-needed horsepower.
    At this point, Jim McDonnell, the company’s founder, began a campaign to raise funding from the military to redesign the aircraft and refit it with Allison or Rolls Royce piston engines, backed up by Westinghouse turbojets in the rear nacelles. The Army turned down his request, instead insisting on more tests of the original design.
    On March 23rd 1944 flight trials resumed, and in May of that year Army test pilots finally got their hands on the aircraft. The XP-67 was judged to offer satisfactory ground handling and a comfortable cockpit. However it was also deemed to be underpowered – something McDonnell already knew and with time would have surely rectified. Perhaps more alarmingly was the fact the XP-67 had some unusual flight characteristics, especially at low speed. It began to buffet well above its actual stall speed, in addition its nose would tuck upwards during the stall. In high-speed turns pilots reported that the tail felt unusually heavy. The unusual flight dynamics were alarming enough that no test pilot agreed to trial the aircraft’s spin characteristics, fearing that any spin would be unrecoverable. It has later been found that the flight stability problems with the XP-67 were probably due to the sophisticated laminar flow design of the aircraft, and had it been a developed now, and fitted with electronic stability aids like all modern aircraft, these problems would have been easily rectified.
    On September 6th 1944 the XP-67 was being piloted by E.E. Elliot during a test flight at Lambert Field in St. Louis Missouri when the starboard engine caught fire. Elliot managed to bring the aircraft down for an emergency landing and he attempted to park the aircraft so the wind blew the flames away from the fuselage. However on landing the starboard brakes failed causing the aircraft to spin around and point directly into the wind. Elliot managed to escape the aircraft safely, but the fire rapidly consumed most of the aircraft. It was unsalvageable.
    Certainly a very unusual subject and very unique looking. This is the first time I have ever heard of it.
      That's cool Tired.
        Not very many aircraft that I am unfamiliar with TI, but you sure found one!! WOW, that is an incredible looking plane!! I am going to have to try to find some 3 view drawings of it, and build me one!!!
          A highly tapered wing like that is a recipe for tip stall.
          Martin.
            How unique is that very cool thanks for sharing !!!
              Martin.
              It's a prototype, we can thicken it up ;)
              1700mm 6S 5000 would be great.
                I dig reading about and seeing the experimental aircraft. The Moon Bat is one of my favorites in a book I had as a kid. Had 3 views of all the X-Planes. This book included experimental versions of the WWII fighters, bigger engines and altered, lightened airframes. Awesome planes. I'm thinking of scratching a edf McDonnell XF-85 Goblin! The test pilots loved how it flew, but had a problem returning to mother ship. :Silly:
                  Cool TI, kind of reminds me if Kelly Johnson got his hands on an F7F-3 Tigercat and tweaked it. ;)
                    Very neat airplane, and love that period of development right after WWII. I can see a flight of these escorting Northrop B-35 flying wings across the Atlantic. It resembles the early jets in a way, almost like a cross between the Meteor and the F9F Panther.
                    • #11
                      Nice one I like that
                      • #12
                        Super unique looking airplane, never heard of it before! Would sure look great at the 2200mm size. Though it really isn't too similar looking, it reminds me of the Hughes XF11 in some ways. That'd be a neat one to see at that size as well!
