Official E-flite 650mm Convergence VTOL Thread
    Well, the programming is quite elementary, so having a file would have only helped the inexperienced and this plane isn't meant for that level of pilot. Any "fiddling" I've done to the travel limits would not have been in the file anyway as it's considered "fine tuning" and personal taste.
  • Brandon Moon
    I noticed that....bad advertising on their part
    I don't think they ever got around to putting the file on the Spektrum page. I've looked.
  • Brandon Moon
    I got it bound...playing arround with it now....
  • Brandon Moon
    I'm using a DX9 TX. set up per the manual. however I noticed they reference a spectrum set up file on the spectrum page, but I couldnt find it there?
    Brandon, this is not god news. Best to check everything. I've mentioned a few things in my past posts that are of concern and these are on units that were better than average. If you're using newer Spektrum gear, binding shouldn't be an issue, however, binding with older gear and non-Spektrum has proven to be a bit of a hair puller. Best of luck.
  • Brandon Moon
    Well, I ordered the Full PNP version and I received mine today. I was a little disappointed to find that the right motor pod servo horn was disconnected and the servo horn screw was missing...not a good first start right out of the box. The instruction on the binding process are less than favorable as well as setting up the FPV gear, though I was able to figure it all out because of my experience from others and past FPV planes I've done.....
    The ball linkages on both forward motors are very sloppy and pop off way to easily IMO....this will need to be fixed.
    I found several screws loose on the wing nacelles and the hatch magnet on the hatch lid was not even glued in.
    Over all first impressions of quality and assembly are not good. I will report back on more after I've finished setting it up and had it out to fly?
    People are debating about how to lock down the props. Back and forth about not using Loctite, using it with care, etc. Simple solution is to use a small dab of FoamTac on the prop adapter threads. I've stop using Loctite on anything on my flying models.
  • Brandon Moon
    Looking forward to giving it a whirl :).... Mine should be here tomorrow or Wednesday
    I flew one of these today for a newcomer to our field. He was very nice and I talked to him about it for a few minutes about what he liked and didn't like, and what he hadn't tried yet, mostly due to nervousness. I went back about an hour later and he was still there, and he offered me a flight on it. I will say that the aircraft feels like it has a lot of potential, but yes there is a learning curve, so approach it as something new and be on the lookout for quirks and new lessons of how this specific aircraft wants to be flown. I recommend lots of open space when you first transition to forward flight. It can really move! As xviper2 said, having adequate throttle before transition is imperative. Overall, points for not making another P-51 or Cub! I only got one flight on it but it did get me excited to fly mine whenever it arrives.
  • Bajora
    A few photos of my first Convergence sighting! Shot a video of one of his flights too. This little bugger is pretty swift when in forward flight!
    Now reports are coming in that the ball links on the motor nacelles are a concern. The ball, after a few flights, can slide through the ring easily and result in loss of control. A few crash reports are starting to come in. Uncertain if it's an equipment fault or pilot error. It may be that a few people got these who perhaps should have flown multicopters a bit longer.
    I flew mine today again in very windy conditions. I extended the servo travel on the nacelles - AUX1 in airplane mode to 110%. This made the nacelles face forward more level. The plane flew really well and chopping the throttle did not result in quite as severe nose drop as before. I will increase to 120% for the next flight. I still think this plane should be able to glide far better than people have reported it as doing. It's an experiment in progress. I prefer to call it "fine tuning".
    Remembering that most twin engined planes have a slight bit of down angle on the motors. This thing comes naturally with some up angle. I believe this was left like that on purpose because to utilize 0 to 100% travel on the transition of the nacelles, they set it up so that it hovered well with just a little forward creep and this prevented them from being level during airplane mode. Extending both ends of the travel gives 1. more authority to stop the creep and to reverse and 2. allow for better nacelle angle for airplane flight, hence reducing the natural tendency for nose dive on throttle cut.
    So far, I really love this plane.
    PS. Transition to airplane flight should be done with hovering throttle. Below this and the plane will drop too much. At transition, the flight controller automatically bumps up the revs a bit to compensate for this but if the throttle is too low, the compensation won't be enough. This is particularly important if you try to transition from the ground or a table. It's got to have enough lift to begin with to hold the weight of the plane when hovering. This is approx. 1/2 throttle or more. So, if taking off and immediately transitioning, raise throttle to at least 1/2 before throwing the switch or your plane will either fly itself into the ground or fall off the table.
    It is a lot of fun and a really neat thing to observe for by-standers. It is for "intermediate" pilots who are somewhat well versed in multicopter AND fixed wing flying. The pilot must be able to switch mindset fairly quickly when doing transitions.
  • PappaBear
    The Convergence has generated an amazing amount of interest. I've had several calls about it. However I can't claim to have flown it, but it does look like a lot of fun and it's something different.
    Martin.
    Maidened mine this morning in the cold and slight breeze. All went well. Took off and hovered a bit and transitioned to airplane flight - smooth as silk. Flew around in Stability mode and yes, it can cover a lot of area doing a circuit IF all you're used to is "bank and yank". Throw in hard rudder and it can be flown in a very small area. Put it in acro/airplane mode and the thing is extremely maneuverable and can be flown in very small area. It'll loop and roll with the best of them. I flew it with the battery about 1/2" back of where it's supposed to be and it flew great. I didn't trim it at all (even though it could used a little bit of trimming), just flew it as is to get used to it. Transition back to hover was flawless and a thing of beauty. With 150% dialed in on servo travel UP elevator, it could move in any direction in stab/hover mode although the response is slightly delayed. It was like the stick was very numb even at full pull. I did NOT yank the sticks around in acro/hover mode but I'm sure it will be very responsive in all directions. Yaw control was not an issue and it spun around effortlessly.
    Someone reported than this plane in stab/airplane mode would drop like a rock when the power is shut down. With my CG 1/2" back, it did not do this to any extent and the plane did glide (although poorly) for a short distance. Glide was much better in acro/airplane mode.
    I am using the Admiral Pro 2200, 3s and the fit was a bit tight. I may have to auger out a little foam so the lid can close more solidly. It closes but not with a solid magnet click that I'm used to. I don't know how people are doing it with the 3000mah batteries.
    One thing of note: My buddy did NOT fare so well (the one in the video above). His rear motor pod came unglued at the seams and his Convy crashed. It was a clear case of poor or hurried workmanship at the factory. I hope Horizon will make it right for him. Myself and the 3rd Convy owner will strengthen the rear motor pod seams with CA and hinge tape before we fly again.
    I am reminded of that whole fiasco with the initial run of Radian XLs, where Horizon had to tell many of their buyers to do some re-gluing of critical areas of the plane that were done badly at the factory.
  • Brandon Moon
    Woo Hoo :) ...just got shipping notice that mine is on it's way :)
    We usually fly together but that wind really spooked me. Mind you, that wind sock is not a full sized one like you'd see at an airport. It's a smaller version meant for RC flying fields. Still, we rarely fly when the thing is standing straight out like that but my buddy couldn't resist flying his new plane a couple more times. He's good enough nothing bad happened.
    Hello XV.............that wind noise on the vid and the sock in the pic definitely indicated a 4-5 Beaufort. ;)
    A minimal joy day for normal fixed wing.
    That is pretty cool.
    Here's a vid my buddy made of his flight in very windy and cold conditions. Winds gusting to over 20mph. Also, attached a picture of the wind sock at the time. His Convergence also had the servo travel on the UP elevator maxed out to 150%. He says it flies great with good reverse authority in hover mode. Neither of us had any trouble binding them to our DX transmitters. I've yet to fly mine. Been too chicken to brave the cold. The 3rd one should be ready by the weekend. We hope to get all 3 in the air together but will depend on the conditions.
    Click image for larger version  Name:	wind sock.jpg Views:	1 Size:	271.3 KB ID:	52988
