FMS 1450 P-51
  • Michael37619
    • Jun 2013
    • 18
    FMS 1450 P-51
  • A6A Hokie
    Hobby Squawk Pilot
    • Sep 2013
    • 29
    • Salem, Virginia
    Re: FMS 1450 P-51
    I noticed in your photo a Dynam Tempest. I have one of these and can not keep the propeller holder on the motor shaft. Have you had the same problem and if so, have you found a 'cure'? Thanks and great flying!!!
    • Michael37619
      • Jun 2013
      • 18
      Re: FMS 1450 P-51
      Hello, I have not had that problem on this plane, although I have had that =
      problem on others. you might consider roughing up the motor shaft so that t=
      he propeller adapter does not slip off as easily, or on the adapter you may=
      need to widen the gaps a little where the adapter compresses, so that the =
      adapter may tighten a bit more to the shaft. I have also discovered that th=
      e upgrade 650kv motor can not handle the stock 13x7x3 propeller so had to u=
      se a 12x6x3 master airscrew on=A0it or consider trying a 13x9x3 on a 500kv =
      version of the motor. =0A=0A=0AOn Thursday, May 22, 2014 1:49 PM, A6A Hokie=
      [via Motion RC Community Forum] <ml-node+s1075610n2307h13@n5.nabble.com> w=
      rote:=0A =0A=0A=0AI noticed in your photo a Dynam Tempest. I have one of t=
      hese and can not keep the propeller holder on the motor shaft. Have you had=
      the same problem and if so, have you found a 'cure'? Thanks and great flyi=
      ng!!! =0A=0A=0A=0A=0A________________________________=0A =0AIf you reply to=
      this email, your message will be added to the discussion below: http://mot=
      ion-rc-community-forum.1075610.n5.nabble.com/FMS-1450-P-51-tp2306p2307.html=
      =0ATo unsubscribe from FMS 1450 P-51, click here.=0ANAML
