pandora cg concern
  • gar
    • Jul 2014
    pandora cg concern
    CG seems to be way nose heavy. Have added weight to rear, and seems to need more. Afraid plane will be to heavy to fly soon. Any one have cg problems.
  • rusted & busted
    • Jul 2014
    • 6
    Re: pandora cg concern
    hello gar. I am using a 2600 3 cell and i added 42 grams to the tail, it balanced out what size battery do you have?
    • Lon
      • Jul 2014
      • 1201
      • Miles, Iowa
      I've been flying in both the high and low wing tail dragger configuration.
      I've never had to add weights to help for CG. BUT, the 2200 & 2600 Admiral battery when strapped in, is very far back. Far back as in, only about 1/2-3/4" of the battery is forward of the battery strap. And yes, I had the battery come loose on a flight, so I added Velcro to the bottom front of the battery and tray. Now, it is very secure.
      Lon
      • WintrSol
        • Nov 2013
        • 499
        • Florissant, MO
        I bored a hole in the very tail, inserted 3/4 ounce of wheel weight lead, and covered it with film. Still, to get the balance better, my 2600mah battery is at the limit of the strap, so I added some carpet tape, to keep it from sliding, and another Velcro strip at the back, so it doesn't shift around and come loose. The battery cable exits the rear, BTW. It is just in the recommended range for CG this way, and flies pretty well, with minimal tail waggle on aileron rolls.
        • gar
          • Jul 2014
          Thanks guys. It turn out the tire i bought for ruff grass were to heavy, so
          I went back to stock and the plane flys just right.
          On Mon, Jul 21, 2014 at 11:51 AM, WintrSol [via Motion RC Community Forum] =
          > and covered it with film. Still, to get the balance better, my 2500mah
          > battery is at the limit of the strap, so I added some carpet tape, to kee=
          p
          > it from sliding, and another Velcro strip at the back, so it doesn't shif=
          t
          > around and come loose. The battery cable exits the rear, BTW. It is just =
          in
          > the recommended range for CG this way, and flies pretty well, with minima=
          l
          > If you reply to this email, your message will be added to the discussion
          > below:
          > http://motion-rc-community-forum.1075610.n5.nabble.com/pandora-cg-concern=
          -tp2649p2790.html
          > To unsubscribe from pandora cg concern, click here
          > <http://motion-rc-community-forum.1075610.n5.nabble.com/template/NamlServ=
          let.jtp?macro=3Dunsubscribe_by_code&node=3D2649&co de=3DZ2FyZWxsaXNvbkBnbWFp=
          bC5jb218MjY0OXwtNzgxMTA1MzIz>
          > NAML
          let.jtp?macro=3Dmacro_viewer&id=3Dinstant_html%21n abble%3Aemail.naml&base=
          =3Dnabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNam=
          espace-nabble.view.web.template.NodeNamespace&breadcrumbs =3Dnotify_subscrib=
          ers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant=
          _email%21nabble%3Aemail.naml>
