Flying Hydroplanes
  • I74
    • Mar 2013
    • 116
    Flying Hydroplanes
    Hi guys<smiley image="smiley_beam.gif"/> ..I see that there isn't much offered of these anymore.. I had the Graupner 3-D Hydro a few years back,, and it was really cool and flew well.. The only down fall of it, was the depron made it delicate.. There was other kits that were more stout, with better frame work.. The vids I saw of these were very impressive.. If you stumbled across a cool design at some point, I think it would be worth checking out,, ''they are a kick''... Ian
  • Tom
    Super Moderator
    • Sep 2013
    • 905
    Re: Flying Hydroplanes
    I've never seen this. There are a few more conventional (not "plain" sea planes) I've flown but nothing like this. I don't see ailerons. Does it use rudder to turn? Does it have rudders under it for water steering?
    • I74
      • Mar 2013
      • 116
      Hi Tom<smiley image="smiley_grin.gif"/> The Graupner has 4 ''big''split ailerons / elev., set up for ''Elevon - Delta mix'',, that are tied together on the wing and aft fuse.. The duel rudders are on the vert. tails also.. Most good kits were like this... There is a ''Hobby Lobby''- Graupner 3-D Hydroplane U-tube vid on it,, also there is a few vids of other brands.. You will see that they don't need underwater rudders at all.. The air rudders on them,,''especially the Graupner'', are pretty big.... Ian
