RocHobby Swift High Speed Maiden Flight
  • Bill
    • Dec 2013
    • 129
    The maiden went well with the high speed swift. Many of the great suggestions from the Forum made it successful. The Swift is my first high speed plane. Here are some things that helped me.
    1. The Elevons need to be set with UP elevator about 2/3 to full thickness of the elevon for the hand launch. Some of the reviews stated this prevents a nose dive on launch, and I believe them. I launched at 60-80% throttle ok. The loud sound of the motor and the strong push of the prop was pretty nerve racking on my first launch.
    2. The hand launch needs to be a good throw upward at about 60 degrees. I almost lost it once with a wimpy throw.
    3. My Swift balanced perfectly with the front end (where the leads exit) of the 2200-3 cell all the way forward in the battery compartment. A small piece of foam aft of the battery keeps the battery from sliding aft.
    4 It really does fly slowly and very fast. This makes it a perfect plane for practicing with speed planes.
    5. The recommended throws in the manual work for me.
    6. I have the $29 Eagle stabilizer in mine. It fits well under the ESC. I do not use it on launching. I use it for high winds and landings smoothly. I have the stabilizer set on low gain for the elevator and aileron settings. It really works well for flying slowly in the wind.
    7. The Swift floats so well on zero throttle that I find I need to give it down elevator to make it fly in to land. Otherwise it might stall as it floats in.
    Boy, what a fun plane.
    Bill
  • Bill
    • Dec 2013
    • 129
    Re: RocHobby Swift High Speed Maiden Flight
    A few things to add after multiple flights.
    With the hand launch, I do get significant torque to the left if the throttle is over 60% and there is no wind to launch into. The torque left at launch is even evident at 60% throttle if there is no wind. Also, there is torque to the left and downward attitude if I rapidly go from 0 throttle to 100% throttle during flight.
    So, I will try to have someone else launch it for me if there is no wind.
    • brick47
      • Feb 2013
      • 54
      yeah these are awesome flyers. I just ordered a complete fuselage + parts to build a 4s version <smiley image="smiley_grin.gif"/>
      I take mine to the field every trip.
      • Bill
        • Dec 2013
        • 129
        I am still having trouble with a smooth launch. I get a torque to the left and barely keep it from crashing.
        Maybe my CG is off some, or maybe the throttle too much, or maybe I am a very bad thrower.
        Do you have any suggestions on the launch?
        • brick47
          • Feb 2013
          • 54
          I've never really had a problem with too much torque roll to the left. give it a good throw more upwards with atleast 75% throttle. make sure your COG is good also <smiley image="smiley_good.gif"/>
          • Bill
            • Dec 2013
            • 129
            Ok. Thanks.
            On Sat, Aug 16, 2014 at 9:13 PM, brick47 [via Motion RC Community Forum] <
            > If you reply to this email, your message will be added to the discussion
            > below:
            > http://motion-rc-community-forum.1075610.n5.nabble.com/RocHobby-Swift-Hig=
            h-Speed-Maiden-Flight-tp3005p3243.html
            > To unsubscribe from RocHobby Swift High Speed Maiden Flight, click here
            > <http://motion-rc-community-forum.1075610.n5.nabble.com/template/NamlServ=
            let.jtp?macro=3Dunsubscribe_by_code&node=3D3005&co de=3Ddy5lLmJlYXNsZXlAZ21h=
            aWwuY29tfDMwMDV8LTg1MzAzNzQ0MA=3D=3D>
            > NAML
            let.jtp?macro=3Dmacro_viewer&id=3Dinstant_html%21n abble%3Aemail.naml&base=
            =3Dnabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNam=
            espace-nabble.view.web.template.NodeNamespace&breadcrumbs =3Dnotify_subscrib=
            ers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant=
            _email%21nabble%3Aemail.naml>
