I ordered a Grand Cruiser and got it on Tuesday . Thanks for fast shipping MRC . As much as I like the Warbirds I really like this style .The twins and low wing I think is very stream line and "real" looking to me .Boxed great no problems , extra props I ordered were inside .
Spent most of the night decaling , assembling , and modifying . I'm spoiled by FMS and Freewing !! The plane is well built but there are a few things to make it better.
The cowls are held on by some kind of double sided thin tape . This is awful , they are hard to work with when you need to get them back off . I cleaned all that off and sunk in a couple of magnets for better removal and replacement of the cowls .
I like having the lights but they are just wires . No connectors of any type .They could have put connectors on with little effort .
The magnets holding on the wire trough covers all came loose . Not that big a deal just reglued the way it needed to be.
Mine came with a bent motor shaft , out of stock but that's ok I'll get a email when back in . Hopefully they will replace the motor will much simpler than trying to remove and replace the shaft. Since both are out of stock makes me wonder if it has been a issue .
I do not like the way you install and connect the battery !! They canopy should be changed to remove and install from the top . I'm not a fan of laying my plane upside down on ground or pavement to mess with battery . That was almost a deal breaker for me .
Came with the hinges but no horns to glue on the flaps , if you choose to use . But like most of us I had a few spares laying around .
I do really like the plane but there are a few things that could make it much better .
