Glue Yellowing
  • Hippie 64
    • Feb 2014
    • 1049
    • Gaffney , S.C.
    Glue Yellowing
    Ok looking for some info . I have a White plane and where the fuse is glued together it is turning yellow ! Anyone know what to do about this ? Granted the plane is four years old
    Bryan
    But Crashing is Landing
  • Beeg
    • 1335
    • Texas
    Paint it.
    • Pauly
      Just Fly It
      • Apr 2015
      • 469
      • Warsaw, NC
      Hippie, I have one that is doing the same thing except the yellowing here is really epoxy where I did a total repair job. I have been thinking of painting it myself.
      Still Learning:D
      • Hippie 64
        • Feb 2014
        • 1049
        • Gaffney , S.C.
        I know there is nothing I can do now but paint it I am looking for a way to prevent it from happening ....
        Bryan
        • doctormike
          HobbySquawk Moderator
          • Oct 2013
          • 1260
          • Santa Fe NM
          I very seldom use epoxy anymore. The new foams allow the use of E-6000 or other contact cements without melting. These glues don't yellow (so far) and allow things to be taken apart if necessary. Nothing short of a jackhammer removes epoxy. If I'm not in a hurry, I often use Liquid Nails Projects glue. It's white and water based. It really holds and can be cut if needed. Doc
          • Pauly
            Just Fly It
            • Apr 2015
            • 469
            • Warsaw, NC
            I really don't know Doc. That was one of the first repairs that I had to do and was told that I should use epoxy. Boy are you right about having to use a jackhammer to remove any. You really can't remove it, but I love now Foam Tac. I did read some where in here the other day that someone else had an issue with glue turning yellow with age. That was after I had seen Hippie with his. Oh, the thing I ran into with the epoxy and I did over do it with the amount I used is the CG. It added a ton of weight on to the tail section it was applied to. I had to add a lot of weight to the nose.
            Still Learning:D
            • doctormike
              • Oct 2013
              • 1260
              • Santa Fe NM
              Yeah...The stuff is heavy to boot. Just don't like it. Doc
              • Hippie 64
                • Feb 2014
                • 1049
                • Gaffney , S.C.
                The bad part is the glue was used in the build at the factory where the halves were put together
                Bryan
