Pneumatic retracts, what do you use at the field
  • Trobinson99
    • 98
    • Ottawa, Ontario, Canada
    Hey all,
    I will be starting a build this fall that has pneumatic retracts. I am gathering some odds and ends while I wait for the kit to ship.
    Part of of my planning is to come up with a field pump.
    What at do you use, hand powered or electric?
    what fittings did you need to make it work?
    Any suggestions on how to proceed?
    T
  • NoDirt!
    • 183
    I use Robart fill valves & chuck. I have a 2 foot piece of airline connected to the chuck (the gold piece). It's easier to screw in the chuck and gives me some more room to move.
    The other end has a football/basketball needle filler plugged into the airline. That is plugged into a $9.95 Harbor Freight 12 volt pump - the yellow.one - which I plug into the panel on my field box.
    I use this setup on two different brands of retracts and it works pretty well.
    • NoDirt!
      • 183
      I used this setup again today. It works well. I guess you could power the pump with a 3 cell lipo.
      • Dewey H Lee
        WARBIRD JUNKIE
        • Apr 2015
        • 919
        • Fayetteville NC. US
        I use the same fittings as Nodirt except for the pump. I use a simple bicycle pump with a gauge im line. 2 pumps and im up to 100psi.
        Dewey l
