Albatross 1275mm warbird
  • DJG
    • Aug 2017
    has anyone had problems balancing their ww1 albatross to make it fly right?
  • wvrailfan
    • Sep 2013
    • 682
    • West Virginia
    If you are referring to the Dynam Albatross, I had to add several ounces to the nose of mine to get it to balance. It is a handful if you try to fly it tail heavy.
    • DJG
      • Aug 2017
      Thanks, Had to put 8oz. in to make it slightly nose down. Will see what happens.
      • fhhuber
        • Aug 2015
        • 1476
        It really needs the weight of a 4S 3000 mah which requires carving a little foam to fit. My 4S 3000 shoved all the way forward has it balanced correctly. A smaller battery (the ones that fit without carving foam) just won't balance it.
        When adding weight, you might as well make it useful. Put in a bigger battery.
        Not recommended for beginner pilots. The adverse yaw can have beginners get in trouble fast.
        Note: The color scheme is one of those used by Richthofen. (The Red Baron) who actually flew more Albatross aircraft than Fokkers. He only flew Fokker Dr-1 (3 different ones with 3 different paint schemes) the last appx 3 to 4 months before he was shot down.
        Yes, the pilot figure is comically out of scale.
