How to secure servo wire connection to receiver
  • How to secure servo wire connection to receiver
    Anyone have ideas on how to secure the servo leads to the receiver in a non permanent way. I have some that are pretty easily pulled out.
    Re: How to secure servo wire connection to receiver
    I have wrapped electrical tape around to catch the sides of the receiver and the connections and worked ok
    But Crashing is Landing
      Have used a wire twist tie threaded thru the installed plugs' wiring & twisted tight on the backside.
      But I prefer very slightly bending the pins to cause a li'l interference, but not enough for misalignment.
      Depending on the plane I might also want to secure the wiring itself near the Rx so if it gets flung around in acro or hard maneuvering it won't yank anything out.
        Thanks to both.
        On Fri, Sep 26, 2014 at 3:19 PM, StarHopper [via Motion RC Forum] <
        > the Rx so if it gets flung around in acro or hard maneuvering it won't ya=
        nk
        > anything out.
        > If you reply to this email, your message will be added to the discussion
        > below:
        > http://motion-rc-forum.1075610.n5.nabble.com/How-to-secure-servo-wire-con=
        nection-to-receiver-tp4102p4281.html
        > To unsubscribe from How to secure servo wire connection to receiver, cli=
        ck
        > here
        > <http://motion-rc-forum.1075610.n5.nabble.com/template/NamlServlet.jtp?ma=
        cro=3Dunsubscribe_by_code&node=3D4102&code=3Ddy5lL mJlYXNsZXlAZ21haWwuY29tfD=
        QxMDJ8LTg1MzAzNzQ0MA=3D=3D>
        > NAML
        cro=3Dmacro_viewer&id=3Dinstant_html%21nabble%3Aem ail.naml&base=3Dnabble.na=
        ml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabbl=
        e.view.web.template.NodeNamespace&breadcrumbs=3Dno tify_subscribers%21nabble=
        %3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nab=
        ble%3Aemail.naml>
