FlyZone Beaver touch up paint
  • FlyZone Beaver touch up paint
    Hi folks Does anyone know of a touch up paint for the FlyZone Beaver with the salmon coloured paint scheme? I spoke to the manufacturer last year and they had nothing available. Perhaps a combination of two colours mixed together may produce something close.
    It's such a nice plane and I have many flights on mine but it is starting to show a little wear and tear so I thought the winter would be a good time to touch it up a bit.
    Thanks!
    Re: FlyZone Beaver touch up paint
    Hi BB,
    No answers yet so I'll offer a couple of tips. If you try mixing your own color, remember paints tend to dry lighter (hued) than they look wet. Do some test 'spots' first - of course, gotta remember your formulae too.
    The other, in case you don't know of it. Take your color - a part from the model or the model itself, into a Lowes or Home Depot paint dept. (eg; most modern paint outlets have the capability now) and let them scan with their color-matching equipment, & mix you a custom sample in water-based acrylic. Samples are usually like ~$6 for a half-pint or so. You'll want to test patch that too, pretty quickly. Let dry & compare; take the sample back for adjustment if needed.
      Content-Type: text/plain;
      charset=us-ascii
      Hi StarHopper. Thanks very much for the helpful info. I never really consid=
      ered that Home Depot or similar would be willing to work in such small quant=
      ities, but it makes sense that they have the technology and I'm sure the cle=
      rk would be willing to help out.
      I will give that a try. Have a great weekend! Bluebird
      Sent from my iPhone
      > On Sep 27, 2014, at 10:30 AM, "StarHopper [via Motion RC Forum]" <ml-node+=
      s1075610n4296h58@n5.nabble.com> wrote:
      >=20
      > Hi BB,=20
      > No answers yet so I'll offer a couple of tips. If you try mixing your own c=
      olor, remember paints tend to dry lighter (hued) than they look wet. Do some=
      test 'spots' first - of course, gotta remember your formulae too.=20
      > =20
      > The other, in case you don't know of it. Take your color - a part from th=
      e model or the model itself, into a Lowes or Home Depot paint dept. (eg; mos=
      t modern paint outlets have the capability now) and let them scan with their=
      color-matching equipment, & mix you a custom sample in water-based acrylic.=
      Samples are usually like ~$6 for a half-pint or so. You'll want to test pa=
      tch that too, pretty quickly. Let dry & compare; take the sample back for ad=
      justment if needed. =20
      > =20
      >=20
      >=20
      > If you reply to this email, your message will be added to the discussion b=
      elow:
      > http://motion-rc-forum.1075610.n5.nabble.com/FlyZone-Beaver-touch-up-paint=
      -tp4285p4296.html
      > To unsubscribe from FlyZone Beaver touch up paint, click here.
      > NAML
