E flight Carbon Z Cub
  • Tom603
    • Oct 2013
    • 40
    A buddy of mine just gave me one these that has been thrashed pretty bad, considering is only gonna cost a hundred bucks in parts to fix I thought it was worth it, considering what it costs new. What would be a good foam friendly adhesive to use on this thing. The gear structure is plastic that has been glued to the foam and it took a good enuf shot that it needs to be put back to original condition. Any ideas or thoughts are much appreciated
    -Tom
    AMA 521691
  • StarHopper
    • Aug 2013
    • 230
    Re: E flight Carbon Z Cub
    https://www.youtube.com/watch?v=Q_pVxYrN_CE
    https://www.youtube.com/watch?v=gDqScpl_6xM
    There's another video I wish I could find again, shows a guy trying to rip 2 pcs of foam apart he'd FoamTac'd & let cure overnight -- he just cannot pull them apart & you can easily see he's pulling with all his might & really deforming the foam but the bond holds. Anyway, this 2nd one is a pretty good example showing the bond is tougher than the foam itself so, check it out.
