FMS L-13 Glider
  • xephyr
    • Apr 2015
    • 4
    FMS L-13 Glider
    Kind of surprised I see so little talk about this glider - not just here, but generally speaking. For an advanced beginner who is turned on by powered gliders (like myself) it has a definite attraction. I've read much about it (pros, cons, mods, etc.) and am intrigued enough to be put it on my wish list. I love it's lines and can picture it flying over the corn fields by my home. :-)
  • doctormike
    HobbySquawk Moderator
    • Oct 2013
    • 1260
    • Santa Fe NM
    RE: FMS L-13 Glider
    Hi, zephyr.. welcome to Hobby Squawk! I won the LET-13 in the social media contest. After much work making it look more like the full scale planes and balancing it at the suggested CG, I found (painfully) that it is extremely tail heavy. It requires almost 40 g in the nose to balance it properly. I haven't had a chance to try it again after all the repairs. I understand it is not much of a thermal glider, but fairly good as a sloper. I would suggest starting with a Radian. I have two, and am very happy with them. They will thermal forever. If you do buy a Radian.. remember to not use full throttle on takeoff and be prepaired to use a little down elevator under power. Once you get it trimmed it is wonderful! The Doctor
    • xephyr
      • Apr 2015
      • 4
      RE: FMS L-13 Glider
      Hi Doc and thanks for your reply! Sorry to hear about your experience.. Sounds like the L-13 could benefit from some "tweaking". Maybe a 3S battery (along with a 30A ESC) would go a ways toward providing the additional weight (and boosting performance) ? - depending on how far forward the battery can be located. Just musing here of course.. I'm flying a mini-radian now and understand it handles much like it's larger sibling. I even had to dive out of the thermal a couple weeks ago because I was losing sight of it. As great as the big radian is though, I'm interested in something a bit different. So many possibilities... ;-)
      • doctormike
        • Oct 2013
        • 1260
        • Santa Fe NM
        RE: FMS L-13 Glider
        I just flew my LET- 13 after adding weight and a 3s battery. It flies great and is aerobatic. It doesn't, however, have much of a glide ratio. Definately a sloaper. I think it would ride a strong thermal. The Doctor
        • doctormike
          • Oct 2013
          • 1260
          • Santa Fe NM
          RE: FMS L-13 Glider
          Well.. after balancing for a 3s 1300 I put a 2s in it. Big mistake!!! I just finished putting it back together. It flyes great on a 3s. Doc
          • xephyr
            • Apr 2015
            • 4
            RE: FMS L-13 Glider
            Sorry to hear it! Must be that threw the CG off eh?
            • doctormike
              • Oct 2013
              • 1260
              • Santa Fe NM
              RE: FMS L-13 Glider
              xephyr...  Have you found your dream glider yet? I think I might have. I bought a Bird Of Time ARF glider. It has a 10 ft wing span and the wings separate into 3 sections. I'm going to motorize it. Doc
              • Flygirl
                • 969
                • Glen Burnie, Maryland USA
                RE: FMS L-13 Glider
                Those are great gliders Doc....
                Lauren
                • xephyr
                  • Apr 2015
                  • 4
                  RE: FMS L-13 Glider
                  No dream glider here yet Doc, but I was out flying my AXN earlier this evening - near perfect weather for it! (for a change). I'm still very interested in the LET-13. The Bird of Time sounds pretty sweet... 10 feet WOW!!!
