Esc battery motor matching
  • Nzpainter
    • Apr 2020
    Hi All, I’m hoping someone can help me out here. I have an easy fly ST-330 someone gave me.
    I bought a new battery for it, hooked it up, it turned on and off every few seconds intermittently and beeped a few times. On the last occasion it was connected I tested the motor for a few seconds to 80% thrust and then it stopped itself, smoke came off the esc and the yellow wire unsoldered itself.
    Safe to say the esc is cooked? I haven’t resoldered it yet.
    So my question is, what’s the right battery/esc/motor setup for this?
    Here’s what I’ve got:
    ESC
    Ble-18
    Max current = 18A, 2-3 cells (Li-Po), with low voltage cut and optional brake
    Battery
    Giant power
    Lipo
    2200 mAh
    11.1v 35C
    (5 C fast charger)
    Motor
    KV
    1000Rpm/V
    10” folding prop
    Anyone?
  • bob_stan
    Old Geezer
    • Mar 2018
    • 96
    • Central New York
    Not familiar with the plane but looking at some on line references I would expect that motor with a 10 inch prop to pull between 10 and 20 amps. I wouldn't have expected your short test to smoke the esc unless something else is wrong - possibly with the motor. If the esc got hot enough to unsolder a wire it is probably toast. I wouldn't trust it.
    • Nike_Belli
      • 38
      Agree with you!
