Elite F-27 question
  • wccox
    • Kansas
    Elite F-27 question
    The instructions to setup the DX6e transmitter is to set the aircraft type as 1 aileron. There is no 1 aileron choice in the wing type settings. Here is what the manual says: CAUTION: Elevon mixing is automatically applied by the AR636
    receiver. If you are using the BNF version of this aircraft, you must
    set the Wing Type to 1 AIL. Changing the Wing Type to any other setting
    will cause loss of control of the aircraft.
    I have the BNF version of this aircraft, but there is no 1 aileron setting. What do I set it as?
