Thrust angle for flying wing
  • Siddesh
    • Mar 2022
    Can anyone tell is there need of thrust angle in delta wing of single motor...and also in rectangle board wing..and if yes then angle measure???
    • 8834
    If it's a "tractor" type (as opposed to a "pusher" type), a rule of thumb is about 3 degrees down angle on the motor and 3 degrees to the right (if you are using a standard rotation prop). You can still make it without any deviation from straight thrust line but then you simply have to use trim to make it fly straight.
