Official Skynetic 1600mm Freeman V3 Glider RTF
    Freeman V3 Glider 1600mm (63") Wingspan from Skynetic - (Ready-To-Fly) - RTF - SKY1047-001
    The Skynetic Freeman V3 Glider is the perfect glider for beginners. Made with durable EPO foam and powered by a pusher propeller, gentle flights are as easy as throttling up and tossing gently into the skies.
    • Made from durable EPO foam
    • Pusher propeller design insures no crash damage to front of model
    • Stable, lightweight and perfectly suited for beginners
    • Skynetic Freeman V3 Glider 1600mm (63") Wingspan - RTF
    • 4CH 2.4GHz Transmitter
    • 2.4GHz Receiver
    • 3S 11.1V 1400 mAh LiPo Battery
    • 3S LiPo Battery Charger
    • Owner's Manual
    Requires:
    HELPFUL TIP: If you are new to radio control (RC) we recommend that you read through our RC resource known as our "Knowledge Blog". It's jam packed with helpful information for beginners including how to articles, support videos, a glossary of terms and much more. Click Here to go to our Knowledge Blog's Beginner Section. For further assistance, please do not hesitate to contact our Customer Support Team and one of our knowledgeable RC experts will be glad to assist you. Happy flying!
    Product Specifications:
    AGE LEVEL :14 and up
    SKILL LEVEL :Beginner
    BUILD TIME :15 minutes
    Model Scale N/A
    Wingspan 1600mm / 62.9in
    Length 960mm / 37.7in
    Weight 800g / 28.2oz (w/ battery)
    CG (Center of Gravity) Refer to the manual
    Power System 3S Brushless Outrunner Motor
    Electronic Speed Control 30A
    Propeller / EDF 2-Blade Pusher Propeller
    Servos 4x 9g
    Landing Gear None
    Required Battery 3S 11.1V 1400mAh LiPo (included)
    Required Radio 4 Channel 2.4GHz (included)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps No
    Lights No
    Hinge Type Nylon Reinforced
    Material EPO Foam
    Skill Level Beginner
    Build Time 15 Minutes
  • Scott Page
    • Jan 2021
    • 14
    Would be interested if 1. it would fly well and accommodate the size of a 2200mah battery. 2. If it was available in PNP. Really not interested in RTF because I don't need the Rx, Tx, battery or charger. I like the color scheme and would use it to introduce prospective pilots to the hobby on a buddy box setup.
    • tab28682
      RC addict
      • 338
      • Fort Worth, TX
      I just do not understand vendors offering so many EPO models with large areas of black paint. They will easily gator in the sun in lots of locations.
      (Not just Motion/Skynetic doing this.)
      • Twaobigv@yahoo.com
        • Oct 2025
        Anybody try slicing half the nose off to place weight in it. As usual factory is tail heavy.
        • AEROBIRDFLYER
          • Mar 2023
          I am betting the battery sits up front in the nose. What I had done on a similar Hawksky V2 glider. I own is to get stick on auto rim balancing weight and stick it on the battery. That would be better than chopping up your plane.
