Anyone know how to unfasten motor? Can't find any access to screws.
FMS MOA 1500 mm
Tags: None
Hello SK23 and welcome to the Squawk,
The Moa most likely has the same arrangement that my larger FMS Fox has and that is a hole in the underside of the fuselage for an Allen wrench to access the set screw used to hold the motor into the mounting collar. Here's the collar and motor for a visual of it's configuration.
Best regards,Warbird Charlie
HSD Skyraider FlightLine OV-10 FMS 1400: P-40B, P-51, F4U, F6F, T-28, P-40E, Pitts, 1700 F4U & F7F, FOX glider Freewing A-6, T-33, P-51 Dynam ME-262, Waco TF Giant P-47; ESM F7F-3 LX PBJ-1 EFL CZ T-28, C-150, 1500 P-51 & FW-190 -
Correct, a 1.5mm allen key should do it. Don't unscrew the grub screw completely, just loosen it enough to allow the motor to slide forward.Live Q&A every Tuesday and Friday at 9pm EST on my Twitch Livestream
Camp my Instagram @Alpha.MakesComment
Thanks OV10 ang ALPHA
Could not get it with 1.5 tried all my hex std and metric. There are 2 access holes either side of nose. Seems like a rounded hole in fastener head doesn't make sense. Ready to cut the foam nose off easy nuff to glue back- just can't see. I found a tel # for FMS and emailed them Haven't given up yet.
Merry Xmas
Hey Matt
crazy thing- not #1 or jewlers work just spin I swear it is a press fit which makes no sense. Oh well thanks for all the help!Comment
.png)
