E-Flite UMX Radian Mini Glider Binding
  • BlueCat
    Where do I look to see the receiver status LED when I'm trying to bind the receiver?
    • 8831
    Don't worry about it. Just plug in the battery, then move about 6 feet away and do the bind procedure on the TX. The TX will tell you that it worked. And you know it worked when the controls work after.
      Xviper2 is right! Welcome to Hobby Squawk, BlueCat! Be sure to range check your controls from about 30 paces as well, before your first flight. Ensure everything moves in the correct directions.
      • doctormike
        HobbySquawk Moderator
        • Oct 2013
        • 1260
        • Santa Fe NM
        Be careful with that little guy. It'll get away from you before you know it. Mine would stay up for hours, no power, if I could stand it. If the wind came up while happily thermaling, it would be in the next state. Fun little glider! Doc
