I purchased the Freewing F 86 Kit just last week. It Went together very well. Only modification was the front two main wing screws were too short and I used a 20 mm lengths instead. When trying to adjust the throttle on the ESC I turn the transmitter on and made the throttle 100%, then I plug in receiver. There is a few beeps and then it started to go through a series of programming beeps. I did not have the codes for the programming The ESC so I just unpluged the battery in the middle of the series. I am uncertain if that change the programming by doing that. Do you have information on programming the ESC in this jet? Was I adjusting the upper end of the Throttle correctly? Any help would be appreciated.
Tom Harris
Tom Harris
