purchased in December 2017. stock set up. noticed flaps would not come up after landing. Occationally one side, usually both sides. If I disconnect battery and re connect, flaps opperate normally. Tried changing channels, sellected new model. new receiver. Replaced relay board as per Motion RC. problem remains. Tried experimenting with servo speed; found that increasing the reverse speed to 100 percent flaps now consistently return . Any ideas?
flap opperation on my Avanti 80 mm sport
Tags: None
I have had the same issue with mine but only one side at a time.Have had 2 (pnp,then arf +). Both very random. Never failed to extend (i take off every time with half flaps ). Never failed to retract half flaps after takeoff. Except for pretty high winds i use full flaps every landing.Had my flaps delayed on first one and a few flights on #2. Set flap to no delay and they have yet to act up. 30-40ish flights since i set flaps 100% speed.Still flying P.15, avanti(#2), mig 21, yak 130 70mm(#2), f35, f9f panther, a10 64mm, F8 crusader/ PA ultimate amr /HK skipper, durafly dh vampire, p 51,spit mk24, corsair, flybeam/ BH f86 50mm, deltawing 50mm/ HH su 26 mm,umx pitts,umx sbach, blade nano cp s,blade 450x, inductrix 200, inductrix pro, umx yak 54,umx f27 fpv/ electrifly 4s L39/ flyzone beaver/ volantix asw 28, /dynam B26
RIP.. roc hobby waco,strega #2(you will be missed), Fw 90mm eurofighter.Comment
