I just ran a static test on my F16 64mm Falcon by Free wing
  • F22
    • Oct 2017
    • 57
    • usa
    I just ran a static test on my F16 64mm falcon by Free wing and I noticed the motor runs a lot hotter than a propped plane regular type example P51 mustang.
    is this because not enough air gets in the duct when static testing it?
  • fhhuber
    • Aug 2015
    • 1476
    Quite possible.
    Strange things happen when you run an EDF with inadequate air intake fr the fan's rpm It might just try to beat the air in the fan into submission without having much effective thrust.
    And then there's the question of how you went about your test. Holding an IR thermometer at the tailpipe while the fan is running would further reduce the airflow.
    And then its possible that the P51's motor is under less % of rated watts load then the EDF. We tend to drive the EDFs right to the max watts the motors can take.
    What temperatures did you get?
    • F22
      • Oct 2017
      • 57
      • usa
      Originally posted by fhhuber
      Quite possible.
      Thank you for the information , I quess I should see how it fly's .
      • fhhuber
        • Aug 2015
        • 1476
        The actual temperatures do matter as excess temperature can be a sign of a problem.
        160 F or above can damage the motors, degrading insulation and demagnetizing the magnets. Once those happen damage just accelerates. The motor gets hotter and produces less power due to the effects of reduced magnetic field strength.
        • AZFlyer
          EDF and Scale Warbird Pilot
          • 194
          • Arizona
          Try running a household fan at it while it's running. Have it blow in the air intake. That gives it some air flow.
          • F22
            • Oct 2017
            • 57
            • usa
            Thanks again
            • F22
              • Oct 2017
              • 57
              • usa
              say that is a good way to test those duck ted fans
