Freewing Mirage 2000C V2 “Tiger Meet” 80mm EDF - Official Thread
    Indeed, good option, and Jetdude, I have no doubt about that at all, I would just do it alittle more subtle is all. :)
      My buddy wanted to paint his hot pink on top...:Silly:
        I got the nozzle and a RCGeek's center afterburner installed, it's almost too much to stand :Love:
        • hotrod23t
          jim jets
          • Nov 2017
          • 312
          • EUSTIS FL.
          i got mine today assembly begins NOW:)LOL:Cool:
          • hotrod23t
            jim jets
            • Nov 2017
            • 312
            • EUSTIS FL.
            OK NOW IM WAITING FOR 1ST FLIGHT:pop I installed a s8r frsky with gyro and telemetry love my Horus X10
            • hotrod23t
              jim jets
              • Nov 2017
              • 312
              • EUSTIS FL.
              Really easy build:Cool:
                I gotta say one of the best radio system combinations ever!
                  More pics of the 3D printed cockpit and a couple of in-flight shots.
                  • davecee
                    • 179
                    • Nashville, NC
                    Sweet!
                      How does she do on grass George? Your field looks to be cut a little shorter and smoother than mine, but not by a lot. The main wheels look good, but the nose wheels look pretty small.
                        I think itll do fine personally. My f18 did well on my field where it's really rough. I'm hoping our guy who mows gets back from vacation soon. It really needs to be knocked down as it is 4 inches tall. :Straight-Face:
                          Here's some more in-flight pictures...
                            Nice!!!!!
                            • Rosytime
                              • 127
                              • Davie, Fla
                              I maidened mine today. Boy this jet is fast. I had too much aileron throw and cut it down after landing. I also put some more expo in it the ailerons. Second flight was much better although the wind was knocking it around. I'm using a Jetwerx 4000mah 60c and it balances a little nose heavy with the gear down. Gear up is fine. When banking the wind can really bounce it around. I am impressed with the power this set-up has. Flying along at high Alpha and push the throttle forward and it visibly accelerates much like a prop plane. Vertical was no problem. Now to try and get it to hover if even for a few seconds. The best part is you only need to fly it at half throttle for the majority of the flight to enjoy it. My timer is set at 3:30 and I'm landing with 35% in my batteries. They were a little warm but I attribute that to the lack of cooling in the fuselage for the battery. Might need to figure a way out to get some air in there.
                                Here's the video...
                                • roys001
                                  • Sep 2015
                                  • 105
                                  • Glendale CA
                                  I've got the plane built and it is a wonderful looking bird. I have an gyro in it that I put just behind the battery bay which meant I had to mount the radio all the way. I've also added the center AB lights from RC Geek. I put the Admiral 4k battery in as far back as I could get it and could not get the plane to balance to the specs in the manual. I had to add led to the back of the plane. My question is, has anyone else had trouble getting the plane to balance?
                                    You have to tuck the battery back in the fuse a little.
                                    • Quickstop
                                      • 275
                                      We have at least 4 mirages at our field including mine and no one had to add any weight, and I'm running a 4500 roaring top with the a/b from the geek. Sepulveda basin in the san fernando valley, come and check.
                                      • Jackcannon
                                        • 26
                                        Maiden flight today went very well. Put 3 batts thru her, fluoreon 4500s with the timer at 3:30. Great flier, very fast! On final she’s very hard to see, so I’m going to add some “metal” to the leading edge. Thanks Motion RC and Freewing.
                                          Welcome to the squawk, this plane does look like an amazing flyer
