stinger 64
  • Clearedirect
    • Apr 2015
    stinger 64
    Hello,
    I have a quick question. I have a stinger 64 edf and it flies great and I've been flying it with a 2200/25c. I put another 2200/30c and everything works , ele, rudder etc but the esc just makes a dull thud noise and resets when you throttle up, It will not turn the motor. Everythings fine with the other battery so I know it's not a problem with any wiring.
    Any thoughts?
  • Konrad
    Banned
    • 733
    • San Francisco
    RE: stinger 64
    Poor solder joint (cold solder). Re do the battery connector or leads on the battery.
    • TOMIN8TOR64
      • Jan 2015
      • 6
      RE: stinger 64
      Check Motor Leads from ESC to Motor, maybe one got knocked loose?
      • Konrad
        Banned
        • 733
        • San Francisco
        RE: stinger 64
        In this case not likely, as the OP stated that the problem follows the battery.
