Dh112 venom
  • Rcrmel
    • 22
    Dh112 venom
    Can someone give me the elevatior travel. Low and high rate. Thank you
  • meadowhay
    • 67
    Here's one I did earlier...https://www.hobbysquawk.com/forum/rc...015#post152015
    • Rcrmel
      • 22
      Thank you. 12mm is the high rate correct? Then what about the low rate for take off and just general flying? I set my low rate at 12mm and that worked well for two flights then the wind was blowing and you can guess the rest. This why I revisited this site to be sure what my low rate should be. Thanks again.
      • meadowhay
        • 67
        That's right, 12mm high rate (I don't ever use low rate) with 20% expo on all surfaces (just my personal taste).
