Customized HSD 90mm Desert Camo Viper Pro EDF Jet
  • SixOne
    Swooosh!!!
    • 43
    My customized Navy version of the HSD 90mm Desert Camo Viper Pro...
ID:	156095Click image for larger version
  • Marco Polo
    Go NAVY
    • Aug 2012
    • 602
    • Illinois
    Very nice, clean lines. What type of airbrush / painting setup did you use?
      Very striking scheme, SixOne, I like your choices! It looks like a completely different airplane to me. For some reason I get a Sepcat Jaguar vibe from the colors.
      • SixOne
        Swooosh!!!
        • 43
        Thanks, Marco Polo!
        I went to Home Depot and got a color match on the light Tan color and hand painted (with a little foam brush) the areas where I removed some of the original HSD decals and placed my own. The darker Khaki colored camo was a paint type used by HSD, that changed colors under fluorescent light, as oppose to natural sun light. So, since I couldn't duplicate that paint type characteristic, I modified the areas that I needed to with the Tan colored paint match. After the painting and decals were applied, I used (spray can) a coat of Minwax Polycrylic Clear Satin for the final finish, which turned out pretty good.
        • SixOne
          Swooosh!!!
          • 43
          Thanks, Alpha!
          The big "Navy" decals on the fuselage and wings are actually from the Freewing 90mm T-45, which I also own. ;)
          • DCORSAIR
            • 1918
            • Selma, Ca.
            Originally posted by SixOne
            Thanks, Alpha!
            I did one similar to yours a couple of years ago, it was a mix of decals from the FW T-45 and 80mm F-86 Sabre, missles and rails are from the FW F-5, my pilots came from the T-45 as well.
            • SixOne
              Swooosh!!!
              • 43
              Cool, DCorsair!
